SunlitComet
OBS Jedi-Do Good
unknown at this time.
My cats are original at 244k and they are definitely not plugged.:D hand it was the msd cap specifically. You do spend a significant time in the cold so it does kind of make you thing you might have condensation issue deterioration. Just a thought.
---------- Post added at 09:37 PM ---------- Previous post was at 09:36 PM ----------
Get a back pressure test done on the cats and determine for sure if you have a clogging problem.
noJeepshere
Bountyfull, Utahrd
What doesn't make sense in this scenario (for the cap) is that it started happening after 5 weeks of over 90 temps. I will investigate and report back.
SunlitComet
OBS Jedi-Do Good
Don't know but when you get it off get some pics for diagnosis.
---------- Post added at 09:59 PM ---------- Previous post was at 09:56 PM ----------
Perhaps the water or air temp sensor could be iffy. or a dirty MAF sensor not responding to air density well. Time will tell.
_Dylan_
STAY FROSTY
If the cats were stuffed you wouldn't be able to drive it, well you could but your not going to get anywhere fast...
O2 sensors unlikely, the engine will run fine in default mode.
Distributor cap is possible. Any codes pop up?
SunlitComet
OBS Jedi-Do Good
well if he does not it does narrow it down to cat problems or high tranny line pressure. weak ignition output could do that too but a failure in the cap would likely be flashing misfires or an alignment code.
Riley you got any type of scanner or scangauge unit?
noJeepshere
Bountyfull, Utahrd
Only codes that pop up are the ones for the EGR valve, which I blocked off years ago and those codes have been there ever since in warm weather. No misfire codes or anything like that. It's odd, it'll run bad for a while after starting, then 20-40 minutes in, it'll smooth out and run like a champ. Hmmm...
retorq
Kingman AZ
Dropped my trans ... like it was hot. Time for rebuild ... bigger and better this time. \m/
Also took a better look at my exhaust, mandrel bent 2 1/2 Y-pipe and stock cat that is ... gutted. Maybe exhaust upgrades won't be next on my list ...
SunlitComet
OBS Jedi-Do Good
which has me thinking because no egr your combustion temps got to high and slightly overheated your cat to a partial blockage. My theory anyway. maybe even a screwy temp sensor some where in the drive-train.
Daddyyukon92
