What do you think is happenning...
Gzes
the drifting 2dr
Wichita tx
Damn sucks to be u. Fedex always gets my shit on time. So when do you think its gonna be road ready?
SunlitComet
SunlitComet
OBS Jedi-Do Good
unknown at this time.
I would like to finish this weekend but unfortunately I am still short a smaller torque wrench for the intake manifold bolts. I got a cheap one from Jegs coming with the heads but they did not have a 1/4". And of course with no control of money coming in I am on a stand still with that part so it holds up. manifold tightening, coolant refill and burp, and start up. I also need to get my hands on an oil priming tool since I would like to see oil on the new heads before first start and the fact it has been sitting a month. Don't want to be turning crank any more form valve settings or clearance checks until I pump some oil into the bearings. That way any debris from job will get filtered by cycling the oil supply a while and when finally run for a few days or weeks change over the oil and filter.
TTZ06
Houston, TX
Its running leaner due to the CAI, the computer needs to relean the fuel trims. Unless you have a scanner to reset them you can unhook your battery for 30 min to clear the memory, then drive it again. it will learn the trims easier that way.
---------- Post added at 06:57 AM ---------- Previous post was at 06:55 AM ----------
Well i guess i could have read the whole thread before i posted haha
SunlitComet
SunlitComet
OBS Jedi-Do Good
Oh, it had the opportunity to relearn already and after a month with out power it will get it again.
---------- Post added at 04:59 AM ---------- Previous post was at 04:58 AM ----------
:laughing1:I was kind of wondering about that comment.
SunlitComet
SunlitComet
OBS Jedi-Do Good
Finally here. Two new gm Vortec heads and used comp cams 1.6 roller tip rockers. Fun should begin Saturday.
SunlitComet
SunlitComet
OBS Jedi-Do Good
Well I still have not got heads on as I have been recovering from a illness but I think I was able to get MSD wires, cap/rotor, 6al digital box and harness in the meantime. Will try to start work again Sunday.
99Yuk
Northern Ontario, Canada
Dang! You are going to have a nice machine when you are done! :D
I'm really interested in those 1.6 rocker arms...Mine are still sitting in it's box....If yours fit ok, and you have no problems, then I might get the courage to try mine... :Handshake:
Your going to really like the all MSD IGN. That really woke my truck up. I figure that I don't have to guess what plugs your going to run eh? :)
Get well, feel better and get r dun!
SunlitComet
SunlitComet
OBS Jedi-Do Good
Autolite 605's of course. As a matter of fact when we each reach 10k miles lets do a plug by plug comparisons for everyone here. The more tech data here the better. could even sticky it. Will update when I check the rocker clearance issue but other user I got them from reported no issues and no push rod mods.
99Yuk
Autolite 605's of course. As a matter of fact when we each reach 10k miles lets do a plug by plug comparisons for everyone here. The more tech data here the better. could even sticky it...
:Handshake: Will do.
For reference, I will post up pics here of the old plugs too...I'll go take pics of them today...
southforkpete
