Should be able to adjust them up a bit.Could I raise it up just by doing the keys? Do I need to do anything else?
I put those Jimmy jamerz, o whatever they're called, on all 4 doors.Well... Went to a kids birthday party last weekend at the mall. Came outside to find someone broke into my yukon and stolet my pioneer double din. Broke the lid off my console, and jacked up my ignition. Not entirely sure how they got in though.
Looks like the tried to pop the door lock out but didn't work cause it's only pushed in at the bottom about 1/8th" top of lock still fine. Door handle is fine.
So today I get to fix the ignition. New double din ordered, and already fixed the console.
Will I have to get it aligned again?screw in the bolts on the keys to raise it up.
Looks like you can raise it up 1/2" and it will be level. That should make it ride better, get the jounce stops a little relief, and you won't need an alignment. That's what I would do anyway.Will I have to get it aligned again?
Here's how it's sitting right now.
View attachment 78566 View attachment 78567 View attachment 78568 View attachment 78569 View attachment 78570
Ok, guess that's the plan then. I don't need that special tool do I? I can just use a regular ratchet?Looks like you can raise it up 1/2" and it will be level. That should make it ride better, get the jounce stops a little relief, and you won't need an alignment. That's what I would do anyway.
