Randeez 2012 Budget Yukon Denali Build (stick on hood scoops galore)
randeez
randeez
south florida
those are the most common, with nitrous tho prob couldve went up another HR tho
thinking about it i was running the 9s for a while and it seems all good until i went up to about 15psi. thats when i started having issues. i swapped the coils and had a full set of 8s thats why i put them in, prob a dumb move on my part. i have a full set + a few spares in heat range 9 now but i ordered some 10s to see if it likes those better
got tunnel vision just trying to swap "bad" parts with wrong parts. also ordered a compression tester cause i couldnt find mine just want to get back to square 1 with a clear head
randeez
randeez
south florida
I hope you have figured out the issue
Is this your first day here? :cheers:
Waiting on compression tester before I put plugs back in, it's kinda a pain with turbo/manifold all plugs are out.
In the mean time, after swapping all the front suspension the alignment was pretty messed up inside of both tires are wore smooth. I adjusted the alignment bolts as far out as they would go but wasn't enough. Not sure if the arms im using bolt up a little different than the 2012 steel arms. i grabbed offset bushings to put in the upper arms, figured i would throw them in while I wait. My dumbass looked at the part while ordering, showed two...but i need 2 for each arm. I ordered new alignment bolts and plates. Same thing showed 2 but I need 2 for each side :emotions122:
And have a single lugnut that doesn't want to budge. I'm talking Dewalt impact for a minute straight with a fresh charged battery. Then 1/2 drive 22mm with a 4ft pipe on the breaker bar, about pushing truck off the jackstands and still didn't want to move. So i dunno might try some heat on it tomorrow.
Dantheman1540
Sugar Loaf Mountain
Got a plasma torch? It can't be tight if its liquid.
BKraft
