Super Moderator
Elev 5,280
Well I have to make my garage a drive-through, and then build a small shop in my back yard, and then I’ll be ok. But yes, I’m working on the old one car 1950’s garage right now. I feel like I’m building a tiny house though....gotta make good use of every bit of space especially since I’ll be basically losing the back wall as it will be an overhead door.
I hear ya. I'd better quit complaining, I've got it good, relatively speaking. I can always park one outside when I need the room, but I don't like to. The Hoe sat out all summer while I worked on the deck wood, and she's lovin' the shelter of the garage.
Sam Harris
Replaced the crap Opt7 LEDs with some more Chinese ones. Lol. These are the Lasfit. IIRC, @Rocket Man recommended them. (Clarification: I only replaced the fogs today.)
Sam Harris
And I finally decided to replace the standard NNBS shifter with the new one that @Adverturedenali92 suggested (maple or amber or something..?) Thanks Chase!! - anyway, color is pretty good. Not exact, but a lot nicer than black. And I bent the shifter arm enough so it’s closer to stock. Much better!
Now, I’ll have to do it all over again, when my replacement shifter boot arrives Wednesday.. [emoji3525]
I left the original in for now because mine’s pretty trashed and suspect it would have ended up in two pieces anyway, had I put it on the new shifter...
Before, with the stock NNBS shifter:
In park:
In drive:
After I bent the arm in the vice, I needed to clean up the shaft a bit since it was a little torn up / rough from the vice jaws:
Now the new park position:
And drive:
Hard to show, but a significant difference after bending the arm, compared with the other NNBS shifter:
Then I started pulling off the shrink tubing I did last time, and desoldered the wires. These are really short, so didn’t want to cut any off if I didn’t have to:
Soldered to the original plug:
And 3 layers of shrink tubing, because I love that shit.. :
Factory plastic keepers hold the wire in perfect:
New park position:
Tow / Haul (BBP “Sport” mode) activates just fine, and the drive position:
In park:
In drive:
And drive:
New park position:
So much nicer. So you bent the shifter up so it sits higher? I need a vise. I bet if I tried to bend it while it's attached I'd def break something.
KEITHC69
