So you just replaced a 4 to 5 year old DS abs sensor? That seems early. What brand bearing did you get? The bearing failing will often show up as an abs sensor fault.
I honestly don't remember what I replaced it with. It was before I was really active on the forum. Might've even been 6 yrs ago. I replaced it because it was making a grinding noise and I felt it through my pedals as I drove.
blueinkd
Dropped new Delco Rad in this morning. Looks like truck was running on OEM radiator as well and it failed at lower driver side corner. PLease make sure you have a decent pair of hose clamp pliers or 2 or 3!!! They are a pain in the rear. i spent more time jacking with the hose clamps than pulling out the rad and fan assembly.
Did you have actual hose clamp pliers or were you trying it with regular pliers? I bought a set of the specialty pliers a couple years ago and now I don’t know how I did without them. They’re great, especially how they lock open.
blueinkd
Was working with this setup.
Knipex cobra hose clamps pliers
Amazon special Ares hose clamp pliers
Blue ones are just Irwin vise grips
Earlier in the year when I did the water pump and all the hoses and Ts, all I had were the blue Irwins. Those knipex those pricey are awesome
You need some like these. You can buy a set on Amazon for about $20. They make it super easy. The clamp is ratcheted open and then the pliers act as a handle to position the clamp right where you want it. image.jpg
I have both upper and lower steering shafts to replace. I'm wondering if doing both at the same time would be easier or more difficult. I was thinking of trying up the steering wheel with the seatbelt to hold it in place, so the steering wheel stays straight once everything is put back together. Does anyone have any better ideas or suggestions on how to conquer this? I'm all ears guys. Tia.
latvius
Ariton Alabama
I use these, it moves your hand gripping action away from the clamp so you don't have to worry about room and it locks open as well.
KodiMoe
