Ball Joints and Sway Bar links
OR VietVet
Multnomah Falls
Military
Willamette Valley
Ok, great...I thought you were saying 2 of the 9201. My mistake and stand corrected. Wonder why the info says 4WD and not 2WD as well? I used all Genuine GM upper and lower arms on both sides of mine and could not be happier, unless they were free. Good luck.
MarshMarlowe
MarshMarlowe
I also wonder why they indicate 4WD. I didn't see any other Control Arms designated as 4WD, and based on what I could xref with my VIN on GMPartsDirect.com, they are the correct PN. We'll see...
MarshMarlowe
MarshMarlowe
Hey everyone. Just finished up with the repair. All said I replaced
Lower Control Arms (GM)
Inner Tie Rods (GM)
Outer Tie Rods (MOOG)
Sway Bar Bushings (MOOG)
Rear Shocks (Monroe) (PITA)
And changed the oil just for fun
This was a whole lot of work, and I really appreciate everyone's help with this. Forums are still the best place on the internet to get good advice and accurate information. BIG thanks to you all
Now just have to get it aligned, and get the AC fixed, and soon change the trans fluid. Hopefully she'll be all sorted out and back to getting groceries, hauling kids to school, and occasionally towing my little boat
MarshMarlowe
MarshMarlowe
Inner Tie Rods (GM)
I guess I spoke too soon. My steering rack is spraying everywhere when I start the truck. Sigh
MarshMarlowe
MarshMarlowe
Did the inner tie rods get installed correctly?
I took off the flexible boots, removed them with a 40mm wrench (I had to use a LOT of force to get them to break free from the rack), Loctite on the threads, reinstalled tie rods, reinstalled boots. Not sure if that's correct
saddam55
