Fuel rail pressure
Another wear item stuck in the gas tank. I like the fact that on my 02 both the fuel filter and the FPR are not in the damn tank. I had a leak and was able to buy a service kit and repair my regulator easily. Plus I change the filter regularly. My CC has a fuel cell and that pump assembly is easily accessible without dropping the tank.
We don't even have a filter anymore, the pickup screens have always been there and now they call that the filter. I went nuts trying to find the filter on my '06 Pontiac, they quit using them too.
I noticed when I installed a new fuel pump last week they moved that screen to the inside of the module too so I couldn't even see if there was one. (the instructions mentioned it was inside) It used to be visible.IMG_8465.JPG
B
Brandon johnson
I noticed when I installed a new fuel pump last week they moved that screen to the inside of the module too so I couldn't even see if there was one. (the instructions mentioned it was inside) It used to be visible.View attachment 201465
What brand pump did you by? And did you have to replace the plastic hose connections for the new pump?
B
Brandon johnson
Replaced the fuel pump with delphi model and Bam. She's fixed. The old lines on top of the fuel pump where pretty corroded so I'm guessing there was a leak from that. Thanks for all the help.
ADO450r
