HELP! Really odd problems...
SunlitComet
OBS Jedi-Do Good
unknown at this time.
If scorched and cracked the temperatures are to high. Can't find a couple pics of own TBI but was thinking if each TBI barrel fed specific cylinders and not just all mixed together perhaps that can isolate a specific injector issue. Otherwise along with something else something might be goofed with ignition system. Maybe wrong plugs even.
T
Indiana
to sunlit, i do believe that my injectors feed to their respective sides. when my right side was dumpin so much fuel. my right side was scorched. now theyre looking fine since i fixed the grounds on that side.
thank you fire, i will look thru those links and hopefully they will help. and yeah its worn me out. me any my wallet both. i have about ten dollars to last me til next paycheck lol. it took two hundred of my money and gave me no answers. im ready to just do a head job on it and replace everything from the gaskets up hahah
---------- Post added at 01:37 PM ---------- Previous post was at 01:23 PM ----------
the first link was good for some general info but the second seems to help a lot. yes my battery cable is quite messed up and i also have the old ACDelco 1 wire alternator... is that bad? and also, how do i measure my fuel pressure?
retorq
Kingman AZ
Have you verified the fuel pressure with a known good gauge?? If that's good then go get yourself a notebook (borrow a friends or drag your home PC out into the driveway), an OBD1 cable and any of the free real time scanning software and log the truck. I bet something in the log is gonna tell you exactly what the issue is.
---------- Post added at 01:32 PM ---------- Previous post was at 01:27 PM ----------
To measure your fuel pressure you will have to put a T in the line somewhere or get an adapter that screws into the back of the TBI. I cut my fuel line about an inch behind the TBI adapter and took about 3 inches of line out, clamped in double jacketed with an adapter to run a gauge.
stoner
Wisconsin
Just a wim. Try a separate ground wire directly from the battery to each head of the engine. Use #10 wire and be sure the contact to the head is to the bare metal so you have good contact. Sometimes the ground can do wierd things as we have found on our race engines. Even though you think you have a good ground as is.
T
Indiana
no i dont have a mac, nor the programs youre talking about, nor a fuel pressure gauge... i have run the live stuff on a snap-on MODIS scanner, is that the same thing? i can probably get a fuel pressure gauge at work though. i just put an airtex fuel pump in it, but if the fuel pump was bad, wouldnt it throw less fuel rather than more?
and thank you stoner, i will try that.
also i am going to try and upload a video of the blazer running, is that possible on this site?
T
Indiana
everything on the modis looked correct. when it was running correctly the O2 was bouncing between lean and rich as normal, then when it ran like ***** the O2 stuck at rich and right when it started to die the injectors started dumping fuel so hard they whistled but that seemed to save it from dying.
what else should i have been monitoring?
T
Indiana
"Battery unhooked for a bit to clear computer, hooked battery back up. Jumped top right two terminals on OBD1 port, turned key forward, waited 30 seconds or so, turned key off, removed jumper, cranked truck.
Two things in that procedure can tell you you did it right: 1) the SES light flashing once, pausing, then twice for a code 12, which is normal operation, and 2) you can feel the valve body of the IAC pulsing as the motor repeatedly draws back."
^^^ so i tried this to reset everything, only i didnt have my SES light flash at me. i turned the key forward for at least a full minute n a half, and nothing. sup wit that?
SunlitComet
OBS Jedi-Do Good
Coolant temp and manifold pressure as seen by computer could provide some helpful data. Also are you saying that in an attempt to initiate OBD you recieved no response from ecm. Otherwise the light comes on when the key is first turned on. Correct?
gottaluv01tahoe
