W8TVI
With mine, the cruse won't turn on at all with the LEDs installed. It could also be a factor in how each different model of aftermarket tails are designed.Hey thank you. I've never done that before so I'd have to look deeper into how it's done before attempting. I noticed that it only kills the cruise when running lights are on or I use my right signal. Maybe same with yours?
I didn't bother to go back and check that reinstalling the stock lights fixed the problem, but the day before I installed them, I used my cruise, and then the morning after I installed them, it didn't work.
My educated guess in how it works is the cruise pulls it ground through the brake light circuit, and when the brake light comes on, the lit filament interrupts the path to ground.
This is guesswork based on how someone explained how the alternating flash on the front side marker light works.
The way yours acts, sounds in line with most everyone else here.
Mine don't work the same way as most people are using.
Mine have the entire LED array lit up at reduced brightness for parking lights, and then the top three rows light up full bright for turn signals, and the bottom 4 rows light up full bright for brake lights. I liked the idea of having more lit up for parking lights.
Here you can see how they work:
I have a few more pictures in my build thread if your are interested in finding out more.
I got lucky and found a set I like that cost less than $100.
