my problem is the opposite I can't keep the bastard cool enough, with a stock setup i run 200-220 in nothing flat, not even towing and even when it is somewhat cool out
That's more than likely because of the way you drive, LOL, plus what is somewhat cool where you're at, 90*my problem is the opposite I can't keep the bastard cool enough, with a stock setup i run 200-220 in nothing flat, not even towing and even when it is somewhat cool out
I eliminated the oem cooler on my suv, also live in TX and we get a light winter.Did you boys plumb your 40k inline with your radiator-cooler, or just eliminate the radiator loop all together?
That’s my problem, too. 200° is easily achieved with the stock “cooler”, and why I’m choosing to bypass it. I hit 223° the other day, and it was only 85° ambient. Hoping this will keep me in the 180° range while I drive it like a Corvettemy problem is the opposite I can't keep the bastard cool enough, with a stock setup i run 200-220 in nothing flat, not even towing and even when it is somewhat cool out
no thermal bypass on mine and even with the deep pan and tru cool on a typical 85-90deg day it will run 180, maybe as high as 190, winter anywhere from 120-165+ which is fine with meThat’s my problem, too. 200° is easily achieved with the stock “cooler”, and why I’m choosing to bypass it. I hit 223° the other day, and it was only 85° ambient. Hoping this will keep me in the 180° range while I drive it like a Corvette
Part of my issue is the 3.08’s, which means it’s downshifting every time I need the truck to do anything with gusto. I have a feeling 4.11’s are going to make me enjoy the truck a lot more.
it is exactly because of the way I drive, silverado does the same thing.That's more than likely because of the way you drive, LOL, plus what is somewhat cool where you're at, 90*
Water begins to evaporate more quickly around 150°F. Boiling point is obviously 212°F, but you’ll see steam much before this, even heating water on the stove.Just some more food for thought... Fluid temps that are too cool won't get rid of moister/water vapor.
Water boils at 212° at sea level.
Discuss.... lol
