Tonyrodz's Tahoe Build Thread
Bear77
South FL
I’m not sure but are those numbers supposed to shoot down in the negative like that
Found this--https://www.performancetrucks.net/forums/tuning-diagnostics-electronics-wiring-161/crank-relearn-explained-sort-344161/
Turn the key to on position
Turn Tech II on
Select the Diagnostics Menu
Select Car Information (Year, Make, Engine, Etc.)
Select Special Functions.
Select Variable Crankcase Learn Procedure.
Follow On Screen Directions.
The Crankcase Learn Procedure is going to ask the Technician to do the following:
Put E-brake On.
Make sure car is in neutral or park.
Turn engine on.
Rev Car to Rev Limiter
Car is done.
randeez
south florida
I wish I knew how to read Live Data.
It's not that simple.... lol
If you're using a maf this doesn't help much, but if your using the speed density
First, the ltft is the changes made according to the stft. I would prob advise against cleaing the ltft because you have no way of adjusting the fueling, whatever changes it has made is only helping.
You need to slowly and constantly accelerate and see what the stft are telling you. Negative numbers mean it has too much and its pulling fuel. Positive numbers mean its too lean and adding fuel.
The table is basically mapd out rpm x load(map). So for 2000rpm and 80kpa there's a fueling cell, 2200rpm and 75kpa there's a cell. And so on. In every direction in every map point.
When it hits on those cells it notes if the fuel its putting in is getting you to the correct afr. Thats what the stft is a percentage over or under
Mine has a maf.
And what exactly is the MAF DTC you have “constantly stored”? Are you positive you don’t have an issue with your MAF?
It's a P0103. I've swapped it with a known good oem maf and it didn't get rid of the code. The plug is good also. It doesn't set the cel but it never goes away, even when I swapped to the other maf. I was told by someone it was the tuner's **** up. I was gonna have the maf tuned out, but I haven't done it yet.
hiltz0517
