the blur
The police pursuit trucks are rated to go well over 100 from the factory. Same truck, but with the rubber stamp approval from GM.
The tires are rated to 112 or 118 mph. I'd have to look to confirm. Doing 100 is perfectly fine, with plenty of room to spare.
and why wouldn't I want to take this vehicle to 100 MPH??? No reason not too !! It's perfectly stable.
Because you only get one telephone call from jail .
theres a bit of difference in the ppv its goverened at 149mph and it has z rated tires wich are 140+ plus also has larger rotors larger alternator a second battery for the communications eqiupment thats required to stayon while the vehicle is off
lower suspension
a ssv is basically the same as a ppv except its 4x4 and governed to only 120mph
