Well, I screwed my self big time.
iboughtatahoe23
iboughtatahoe23
I took the fuse out and then put it back i, turned it over on accessory a few times and it stopped doing it, the lights would shut off when I opened the door. And then I turned the car all the way on, and drove home and it did it again when I shut the car off. So that tells me it only stops doing it when I take the fuse out and put it back in and then don’t start the car.
iboughtatahoe23
iboughtatahoe23
Ok now the radio is charging my phone via the usb dock in the center console…. But the car is all the way off….. wtf this is new.
iboughtatahoe23
iboughtatahoe23
Just adding stuff as I find it:
I noticed when I take the radio fuse out the message Center will say Park assist off, but it will still work?
GMT800 SUV/Trucks
I truly believe, I take that back. I truly am guessing that if you find the fuse/relay box that controls all these, I bet it is the same box, and remove all fuses and relays and inspect and clean as needed and remove the box from it's mount and inspect/clean the back, you can repair your problem. Different items are getting power when not needed and vice versa.
I had a Chevy pickup once that would not allow engine to shut off unless you turned off headlights. The back of fuse box was cruddy and like crud on top of a battery, was allowing voltage to travel.
iboughtatahoe23
iboughtatahoe23
I’ll be you tubing how to clean a fuse box tomorrow then…. We will see if that works.
bobbywdatool
