Where is the leak? Oil Pressure Sending Unit Replacement
#1taho
5150TAHO
niagara falls ont
couple more pics. Valve cover bolts seemed plenty tight. it sure looks like they are dry to me (everywhere i can see). the only wet thing on top i see is actually around the filler neck, it looks like its not really in there very well haha.
here's some pics, as good as i could take, the valve covers look nice and dry? btw, anyone else have problems uploading pics from phone? i always have to resize them down on my computer now since the site changed.
I have a motor out on the stand, i see your complaint on the back of my motor, I think it's could be the cam sensor right next to the oil pressure sensor. I have the same oil leak i am trying to fix before it goes in.
I think it will be very hard to see in the truck but try to have a very good look with a mirror, maybe that could be your problem. yes I have to resize the pictures also. i will try to get a pic of the back of my motor to show you.
#1taho
5150TAHO
niagara falls ont
Right beside the oil pressure sensor is another sensor. My guess is it's the cam sensor. My is wet like you two. The oil thing I can think of is its the sensor on the right. I hope this helps you guys. I will be taking it off later to see if there is an o-ring.
#1taho
5150TAHO
niagara falls ont
Ok. I had a few mins so here it is. It is a cam sensor but the oil seal is at the bottom. Not very smart of gm. On the top no gasket or o-ring. This seems to be my problem. image.jpg
#1taho
5150TAHO
niagara falls ont
it will be tight but it should be doable. 10 mm is the size of the bolt for the sensor,to turn the sensor a few times and get a small pick to lift it out. shouldn't be too hard , move your oil pressure sensor to have that extra room. let me know how you make out.
