retorq
Kingman AZ
Pull the header heat shield off, broke a while ago and makes a weird rattling noise every now and them. Did a flush and oil change, greased ball joints and rod ends. Also had a spark plug wire resting on the header, burned thru, moved it for now, much better lol. New plugs, cap, rotor and wires will be up soon.
noJeepshere
Bountyfull, Utahrd
I suspect the fuel pump. :(
cent frum a smaert fone
_Dylan_
STAY FROSTY
Pull some spark plug boots off, jam a screwdriver in them, and check for spark by placing it about 1/4" away from something metal. If you have spark you will see it grounding out to the metal.
You can check for fuel pressure by pushing down on the schrader valve on the fuel line on the back of the intake. If you have fuel pressure gas will squirt out. Can you hear the pump running?
noJeepshere
Bountyfull, Utahrd
Can't hear the pump at all and it still has spark. Just shut off like I turned the key and nothing after that.
eb5665
