It is for a 4wd rig. Not for yours. So, you are backing away from the MOOG parts?
The easiest way to confirm the part number is to call your local GM dealer and give them your VIN, and ask them for the correct part number.Can anyone clarify whether this is the right lower control arm for my 2012 LS 2WD Tahoe? The 4WD in the description is giving me pause
Thank you. Using that method, it appears the part that I linked is correctThe easiest way to confirm the part number is to call your local GM dealer and give them your VIN, and ask them for the correct part number.
Another good method is to go to GMPartsDirect.com and enter your VIN. Then, in the search field, enter 'lower right control arm'.
I'm so jealous of you guys with the 2WD's.You may want to leave any plastic wrapped bushings sealed. This is the only original not split or warped bad. I had just removed it before this pic
Lousy dealer, but I understand. Good luck with your project, and please report back your results.Thank you. Using that method, it appears the part that I linked is correct
EDIT
The dealer won't give me the part number, but they'll be happy to order it for me. LOL
Are you saying the lower control arms are the same left and right? Look at the pics of this arm at the RA site. They look different to me, left and right. Just sayin'.Well I pulled the trigger on the 20869201/2 GM Control Arms, 2 GM inner/outer tie rods, and Moog Sway Bar links
All from RA. Fingers crossed
